How to get your Huawei Auth Key code
The Auth Key is a secret code that is generated by the official app to be able to connect with your watch.
Auth Key is required if you want Notify App to connect with your watch (even if the official app is installed). When using a wrong/different Auth Key watch may reset.
Available methods to obtain your Huawei Auth Key
Automatic method
  • Install the official app and pair your watch
  • Be sure to use an email to do the login procedure on the official app (do not use a social login like Facebook, Google, ...)
  • Uninstall or disable Bluetooth permission for the official app without unpairing the watch
  • Install the Notify app, and follow the initial pairing tutorial by selecting your watch
  • On the second wizard activity, you will be asked to input your watch auth key, press the Get button
  • Follow the procedure by doing the login procedure using your previous account (email+pwd)
  • Done! Your Auth key will be inserted automatically on Notify app, and you can finish the pairing procedure
Authkey suggestions and notices
Unable to obtain your auth key with any method? Try to hard reset your watch from the Settings menu (on your watch), then reinstall the official app by creating a new account (email method) and pair your watch.
- If you reset your band, the Auth key may need to be calculated again
- It's compatible with any firmware version installed on your band
How to get your Auth Key manually
  • Open https://cloud.huawei.com/ on a browser using Desktop mode (not small screen)
  • Login with your account credentials
  • Press F12 to open Developer mode
  • Go on Application tab -> Storage (names may be different)
  • On Cookies section find out the cookie named userId
  • Now you have got your Auth key code: 5110012000021124567
How to get your Auth Key on a phone ROOTED
  • Ensure the official app is installed and paired correctly with your watch
  • Connect your phone to the computer
  • Ensure adb is installed and working correctly (google adb install for more instructions)
  • Open the console command line on your computer
  • Execute the command: grep old_user_id /data/data/com.huawei.health/shared_prefs/login_data.xml
  • You should obtain a result like 5110012000021124567
