There is a way to disable the vibration at every heart rate measurement? I have set he measurement every 30 minutes, but it's very annoying to have the Arc vibrates every time..also during the night!!!
I found a solution for my Mi Band 3 : I decided to try changing the "heart monitor mode", I think I picked "use notify app and mi band device", that was then end of my plan but when I went back to the previous menu there were new options including 2 enabled "vibrate if heart rate less than x" and "vibrate if heart rate greater than x" - both options enabled and both set to zero. Have turned them off and changed back to "use mi band only" and problem solved. Interestingly it is also apparent that it is the heart rate monitoring that canes the battery on my phone.
Have raised the same issue, driving me to distraction and only day 1 of using the app.
