Weather and temperature problem
I cannot get current temperature to display on any watch face. The forecast will display.
The weather settings pages shows an error that I need to select a location (even though I last known location turned on) when I press to pick a location I briefly see the map loading, then the app crashes. This happens consistently.
Would setting this location help with the current temperature display?
  • I'm having the same problem.
  • Cannot get to display current temperature with any of the data providers on any of the watch faces. Current temperature worked fine when using Mi Fit app. I have uninstalled Mi Fit app now though.
  • edited August 2018
    Same here.
    Please fix it.
  • Strange, i have no problem with weather or temerature.
    Works normal for me.
    No have problem with current weather and temperature. But i have problem with humidity is not showed in weather app of watch, i have aqi value and the word humidity but no value.
This discussion has been closed.
