[5.5.6] Annoying notification sound
edited April 2018 in Problems
There is a problem with the newest version 5.5.6: every time you enter in the app or the notification is auto refreshed there is a notification sound played in the mobile. Its really annoying.
Previous versions were silent.
Im using android 8.1.0.
More info: if you put phone in silent mode it vibrates twice instead of play the notification sound.
The way to get rid of these sounds/vibratios is uncheck the "Prevent app get killed (show notification)" option.
Again more info: in the android notification center for this app there are two categories. One of them is named "running" and its the one causing this behaviour. It can be disabled from there.
Thanks and best regards.
  • This just drove me mad for a while, I had updated my phone firmware and thought I had done something wrong.
  • Another effect of the new notification: now it's always shown, even in lock screen.
