Band high battery drain
edited December 2021 in FAQ
To solve band high battery drain
  • use a stock watch-face
  • reduce / disable heart monitoring usage
  • use heart monitor "band only" mode
  • reduce vibration usage (notifications, alarms, ...)
  • disable or set button mode to normal mode
  • disable Anti-loss my phone on tools section (the last option)
  • disable Sleep as Android tracking
    Still not solved? Reinstall app to restore default app settings.
    Hint: there is also a reset app settings on the app general settings
Old band
Disable phone Bluetooth (or install only official app) to ensure battery drain is not related to Notify app
