Phone battery drain
To reduce phone battery drain:
- reduce / disable heart monitoring (especially do not use continuous heart monitoring)
- reduce notifications usage (repeat only first time, ...)
- do NOT set button mode to performance mode
- ensure band is paired correctly Check pairing tutorial
- disable notify backups (on app general settings)
- disable google fit automatic sync
If you think you have no wrong configuration, please uninstall and reinstall the app to restore default values
