Band battery drain
To reduce band battery usage:
Disable also heart monitoring to save band battery (disable also sleep heart assistance option)
Reduce notifications (vibrations) usage too
Use a stock watchface to reduce battery usage
May need repair band if is not paired correctly http://forum.mibandnotify.com/discussion/184/connection-pairing-sync-issues-solutions?new=1
You can enable power saving mode on notify app advanced settings
Band battery drain could be related to a buggy firmware, so downgrade (install an older firmware version) if you have updated recently.
To install an older firmware version, go on update firmware and choose an older mi fit apk version
